young tractor
Hi guys,
I am usually in the Oliver form, but a have a large question for you. I recently purchased a self propelled combine and no longer need my AC-90 pull type combine. I am very partial to this old machine because I have darn near replaced everything in the rebuild process. I am not looking to sell it here, I am just looking for a rough price of what you think it should sell for. I don't have a clue what it is worth in the collector market as I used it to farm. I will list everything I have done to it. I have run about 13 acres of wheat through it and about 25 acres of soybeans. It made amazing samples in the grain tank. Almost all the parts came from Yaz all crop. He is amazing.
-all new bushings in the straw walkers
-all new hardwood chain guides and wood block bearings.
-all new belts including the cylinder belt
-all new wood reel made out of oak.
-New shelling plate rubber
-new cylinder rasp bars
-new wood block bearings in the scour clean
-adjusted all elevator chain correctly
-new concave rubber
-new sickle sections across the entire bar
-new sickle bushing
-new cable lift cable
-replaced any bearing that was suspect
-new chains where needed
-gear box doesn't leak at all
-new dual grain tank tires
-has a straw chopper
-new paint
-new decals.
What do you think guys?
-new concave rubber
-new sickle bushing
-new paint
-new decals.
