XT190 brakes or lack of
old
So the I-T manual is not all that good as to the brakes on this thing. I have to tear into them since there is no brakes at all on this. So are they and or disk brakes or does it change by what year it was made??
Thanks
The last one I worked on had band over disk. When the band is applied, big ball bearings inside the drum force it apart, causing the disks to slide out against the housing. If the wheels are set in you gotta be skinny to work on them. Frozen band pins, mickey mouse springs to contend with, and there is a clearance you have to go by, meaning adding or subtracting shims.
I have the I-T manual AC-202 which covers the D-19 and the 190/190XT etc. But it is vague in many ways
I am on the skinny side so that will help but it also has a loader on it so that will not help. The left side looks easy to get to but the right side has a couple control rods in that area so will be harder to mess with
