Billy_The_Kid
The portion of the PTO shaft that is splined was bent by the previous owner. It wobbles about a half inch out center, enough so that when I connect a shaft with a universal joint on it, it wobbles significantly, but still does function.
Is there a recommended way to get the wobble out, or is it easier to simply replace the entire shaft?
https://picasaweb.google.com/lh/photo/_Esc6CI4E-RZ4tx2i-XTnTGH-xLS3o2Aqg1-xPX1Gdw?feat=directlink
