Allis 180 rear axle shaft question
The early 180 rear stub axle #70252151 has threaded lug bolts. The later serial number axle #70240191 has smooth lug holes and uses bolts and nuts. I can't seem to make the old number sub up to the later type. Will these axles interchange with the right lugs?
(quoted from post at 10:57:21 02/11/15) The early 180 rear stub axle #70252151 has threaded lug bolts. The later serial number axle #70240191 has smooth lug holes and uses bolts and nuts. I can't seem to make the old number sub up to the later type. Will these axles interchange with the right lugs?
They should, I know the whole final drive assembly does.
