ED 40 fuel filter
4wdtom
I am helping a friend with work on and restore an ED 40 and we need to find a fuel filter. Have a parts book and Sandy Lake says the number is good, but that there are no filter elements in North America. Does anyone know of a filter that will fit and work?
Also would like to talk with anyone who has an ED 40.
Thanks, Tom
The information below is from an earlier post on
YT. Also, the Fegurson TO-35 used the same
Standard diesel engine. I am not sure if the
filter was the same but you can check for size
comparison on:
agcopartsbooks.com
Found on the 'net:
Allis 725429 Description:
Length Or Height: 71.45 mm,2.813 in
Outside Diameter Top: 82.55 mm,3.25 in
Inside Diameter: 16.66 mm,0.656 in
Inside Diameter: 19.05mm, .75".
POSSIBLE replacements (Verify dimensions/fit, and
filtering "specs" (microns) and use at your own
risk):
ALLIS- 725429
CYCLONE- 138364
FRAM- C11838
Co-op- FF11838
MOTORCRAFT- SFG154
VOLVO-7078472
RENAULT-3005821
WIX- 33114 is CLOSE, as well.
OBVIOUSLY for any filter you attempt to use,
verify that it seals top and bottom and will fit
in the canister w
LARRY... the information above which you are calling "earlier" was posted by ME just today in response to 4wdtom's duplicate post on "Tractor Talk".
You did good research on it. I think I used the WIX 31114 on my Ferguson TO-35, but I could not find the box. I had an ED40 for a while but got rid of it because it is difficult to find parts.
