Assembling Allis Chalmers G
Mark Gundrum
New User
I am putting together a G that I did not take apart. On the clutch pedal how to get the spring over the rod and in between the axle housing and throw out bearing bracket. Also hooking up throttle rod where it attached to carb and how and where does does guide bracket attach to. Lastly where does wire harness attach to on engine block. Any pictures would be a great help. Thanks
Find what you're looking for among the bunch of pictures or should I go to the shed with a camera. I've been into both those areas on mine, but just don't remember without going out to look.
Hi Leon and Thanks for getting back with me. Pictures would be helpful. I have the clutch rod figured out. Not sure where and how throttle lever is attached to carb. Also does wire harness run underneath gas tank and radiator? Again pictures would be helpful and Thank You again.
Mark Gundrum
Well, let's see if I was successful in uploading photos.
The guide bracket goes over the manifold flange on one of the studs. It's behind the rightmost spark plug wire in the third photo. You can see the lower right corner of it below the arch in the carb rod. I bought a manifold from Stiener years ago and the flange was too thick so the rod would not line up to the governor.
Hi Mike,
Sorry to be a pain. From the back of the engine which stud does guide bracket go on? My manifold came from Steiner. What needs to be done to make it work? It appears the studs are not long enough for bracket. Can studs be replaced or do I need to mill thickness off bracket?
Thanks
