AC identification?
got a chance to buy a partially dis mantled AC tractor; probably a D-15. It's a 4 cyl gas,block casting# J126,torque tube has has a casting # of 263845. 3pt hitch and middle arms. rear tires are 12.4x36,fronts are 5 lug. Any educated guess on what it is? What is a ragged runner worth?
On the left side of the torque tube it should have the model and serial stamped. Also a picture would help. D10, D12, D14 and D17 all pretty much look the same unless they are side by side then you can see that one is a bit bigger then the other
A D15 would have 26" rear tires unless it's a high clearence model. Like Old said look for the model # on the torque tube and the engine # just to the rear of the carburator. Bob
I would suggest go to Google or Bing, type in D19, D17 etc. one at a time and look at all the pictures of each model.
Bill B
The D-19 has a 6 cylinder gas or diesel engine so it would not be one of them unless the guy can not count to 6
