sandman2234
A while back, one of the more frequent posters on this forum posted a sheet from a manual that gave the directions on how to adjust the hydraulic pump on a CA. I have spent several hours trying searching, trying to find that sheet. I knew I should have copied it and printed it a dozen times and put a copy in every place I might have thought to store it, so when I needed it, I would have it. I didn't...
So, would somebody tell me where that post went, or kindly post that sheet again so I can fix my durn ca so that the 3pt will drop. It will stay down until you touch the lift handle, then it goes up and won't drop till you open a hose fitting and release the pressure.
Thanks, David from jax
