oil filter for Allis B
any of the three listed will work fine. Always open the box and look at the open end of the filter. It should look like it is stuffed with a cotton rag with a 1/4 inch hole thru the center. Might have a dowel in the hole, maybe not. IF it looks like a car filter with a paper pleated fold pattern... you don't want that !
Just be sure that when you remove the old filter that the oil tube is there. If not you will have no filtration or oil pressure.
(quoted from post at 08:42:12 11/01/14) I use the Wix 57011 and have for decades
Fleetfilter carries them on-line....same as the Napa gold 7011 for about half the price. Plus, get 10% discount if you order $100, 20% discount if you order $200.
