Just got a D17 Series II. It was connected - ground when I got it. The lights didn't work and the battery wouldn't charge. I switch that around so now I have lights but the battery still isn't charging. I polarized the generator before starting it but I'm wondering if the damage was already done before I got it. One point in the voltage regulator was stuck and looked burnt. Also, I checked voltage across generator posts with the tractor running(F & A) and it shows no reading. Should there be voltage on the generator even if the voltage regulator is shot? I did notice one of the post on the generator is loose. The ammeter goes way negative when the lights are on. Do I have to go to an AGCO dealer for a voltage regulator?Can the generator be repaired? Hopefully I can get this resolved before it starts snowing! Thanks
