D10 clutch noise
Not enough info there...
Could be a throw-out-bearing, bad pressure-plate or loose/broken lining on the clutch-plate...
Ron.
You weren't mowing up & down a very steep hill, leaving it in gear and releasing the clutch letting it roll back down the hill, were you? That can oper-speed a clutch so much that it can tear the facing apart and throw segments off.
