Would would think it could be since the engine from either will fit in either one
Thanks to all for info.
My WD is an early model. It has a WD45 engine. The pto intermediate gear and pto housing are shot. We have a complete WD45 transmission with Pto available. We thought it might be easier to swap the transmissions rather than try to replace the damaged gear and pto housing.
rowtohoe
WD-45 has a synchronized transmission, the WD has Straight spur gears.
You will need to change the entire transmission or contents.
Be SURE to have the Lower PTO Gearbox and Gears Magnafluxed, to be sure they are Good, Sound Pieces.
Ron.
