IB Allis wire diagram
Bob Evans
I have an IB Allis that is still 6 volt with a cutout on the generator. I would like to change to a voltage regulator and need a wiring diagram to go to a voltage reg. If anyone has this diagram I would sure appreciate it.Thanks
Generator side of cutout to ARM or GEN on regulator
Output side of cutout to BAT terminal on regulator
Disconnect F (field) wire at generator. It came from the Low/Hi/Light switch. Remove or tape off the old wire. Connect F terminal of generator to F terminal on regulator.
If regulator has L terminal leave it blank
http://i436.photobucket.com/albums/qq86/steve-ill/a5464.jpg
