I am restoring a 1952 Allis Chalmers WD. When we opened the transmission up, it was full of water and bearings / gears rusted.Because of this we are having to replace the bearing cluster on the transmission mainshaft. To replace this, there is a mainshaft rear bearing adjusting nut that has to be removed. It looks like at the factory they heated part of it, bent it in to serve as a lock. I am curious if any of you have ever messed with removing this nut and the best way of going about it. We have heated it, used a punch to bend it out but it doesn't seem to be bending out enough to unscrew. Any good ideas let me know! Thanks!
