allis c engine swap
About four hours if you have everything ready. Plan on taking a day. You will have to use the clutch assembly and will need four step studs from 5/8" standard thread down to 1/2" fine thread to bolt the front casting to the block. The CA used the step studs.
Some hole changing in the hood.
Sorry! I didn't finish my thought when typing.
(You will have to use the clutch assembly from the C.)
Yes you will need to use the C flywheel and starter. the ring gears have a different tooth counts.
You also need to use the C fan.
On the hood, you need to move the muffler hole, the oil fill hole and the C air filter will not fit. You can drill out the radiator mount to a size to fit the D14 studs if you don't have the step studs.
Bill B
