Allis 185 front wheel beairings ?
I looked in my parts manual and there was supposed to be two thrust washers on my King Pins, Looks like I will be putting new thrust washers in plus wheel bearings and new bottom king pin bushing on this side.
Should I have to use a jaw puller to remove this bearing, it moves to here then stops.
I don't want to force it.
Thanks Jeff
There were different thickness thrust washers so make sure you add the right amount. The bearings should come off the spindle pretty easy, but you may have to tap them lightly. The races I used a hammer and punch to drive them out of the hub. If you have a press to put the new races in it makes the job a lot easier, just make sure you put them in the right way. I found that out the hard way!!
