WD 45 hydraulic level
deerman
You can laugh if you like but where do you check the hydraulic level. Is there a dipstick? Where would you add hydraulic fluid. This particular tractor has power steering and a loader. There is a small bowl under the hood that has hoses running to power steering pump. Got the tractor running good but loader will not lift and steering does not seem to work.
You need an Operator manual. There is a bayonet gage on the left side of the tractor, forward of the foot clutch pedal, for checking hydraulic fluid. That is also the fill location. Your PS unit may have a separate reservoir, depending on brand.
