D-17 Diesel
Matt33
New User
I have changed my fuel filters and sense changing them the tractor doesn't really want to run. I have cracked the injection lines and very little fuel comes out when trun engien over. the tractor has started and ran a couple of time for to mow, but now it is dead in the yard. please any help would be great.
Verify you have good flow into the pump, then start bleeding at the pump, and work your way to the injectors. Sounds like air is still in the system.
might want to check the return line if it is stop up.
then it builds to much pressure and will hydro lock up the injection pump.
There is a small check valve at the top of the pump.
This usually is a sign the flex ring is going bad in the pump.
Like all the other said make sure you have good flow.
