WC 12 volt conversion benefits?
48C-MAN
I have a WC with loader that I use more in the late fall/winter than I do in the summer and also have a WD 12v neg ground. The WD seems to start better in the winter due to the faster starter speed. Will my WC see the same improvement if I convert it? Thanks, Jeff
Yes it will start faster with the 12 volts. The only negative thing about converting to 12 volts is it is hard on the starter drive springs.
Yes, it will improve starting...they both have the 201 engine...WD is governed a bit faster. Starter generally doesn"t have to crank as long.
