rosedale123
here is my ordeal
new head, new intake manifold, new carb, rebuilt mag ( done right), new wires , plugs, oil
my test start did not goes so well. It starts and runs about 2 seconds. starts back up - for another 2 seconds.
compression is good ( 100 - all), good "suck" when I hold my hand over the intake while turning, valves adjusted cold to .013, good fuel flow to carb, plug plug our of carb andstill good flow. spark is great, timed cold with timing mark
Sounds fine for those 2 seconds. I can keep it going a little longer if I spray starting fluid into the intake. took the carb apart and blew out main jet - it was clean
Seems like it starves for gas real quick but this doesn't make sense to me
Can someone help me out - frustrated
