185 oil leak
Anonymous-0
Hello all. Posted a couple weeks ago I was looking at a 185 with a slight noise in the transmission . Got her home today ,decided to put her to work a little . Brush hogged an hour or so. Noise quieted down some , still gonna pull it apart . Now I have a steady drip of oil coming from the hole where right brake actuator comes out of the rear end . The rod doesn't pass through a seal there does it ? Thanks for any input .
Most likely the seal that leaking is the one for the ring gear assembly. While you're in there, check the bearings, they may be worn too.
