CA lift problems
super6
I have a 1952 CA that runs great. Last week I was grading the driveway with my snapcoupler grader blade, when the hydraulics started lifting very slow. I checked the fluid and it was up. Does anybody have any ideas on how to fix
I do not know much about the CA but if like the WD/WD45 they have knob like thing that can vibrate and move that will cause to thew happen down on the hyd pump area
On the WD and WD45 there is a knob that if moved causes the lift to slow down or speed up I learned that the hard way when it got turned and almost stopped the system on a WD I had
So it should also have the flow control valve then which can cause that type of problem
If the pump is set for traction boost, this will happen if enough pressure is applied to the snap couple linkage. You NEED to set your hydraulics for hold position,not traction boost.
