chris rolke
my brother and I picked up an allis g a few years ago. we had gotten it running but when you put in in gear and let out the clutch it didn"t move. time went by and other projects came up, now I am wanting to mess with it again. after some reading I went ahead and pulled the motor out of the tractor figuring the clutch was stuck.
with the motor out I pulled the clutch off and checked out the pressure plate and clutch disk. they are not in too bad of shape. I cleaned up everything and put the clutch back in tightened up the pressure plate and tried to move the clutch disk with nothing pressing on the pressure plate and it wanted to spin the motor over so it seems like the clutch and pressure plate are holding. went ahead and pulled out the throwout bearing and pin that holds the clutch fork and cleaned them both up so everything looked good and put the motor back in. once I got everything together I put the tractor in gear and moved it back and forth and it never tried to turn the motor over. I have not tried to start the tractor yet (getting too late) what kind of adjustments should/ could be done to the clutch?
anyone got any other ideas about what to try ?
thanks for any ideas
