Show Parts for Model:
AC WC steel rear end
Rodger 56
08-30-2014 04:20:59
I have a WC with a steel rear end and like some information. Can"t find serial # left axle. What years made, weight differents in cast iron, number made and any other infro that may be helpful. Thanks
Rodger 56
08-30-2014 16:21:23
 Re: AC WC steel rear end in reply to Rodger 56, 08-30-2014 04:20:59
Thanks guys for the infro. Found serial# right where you both said. It's 134707 makes it a early 1945. I brought it at the Polk Auction there was 900 plus tractors and this one caught my eye. Thanks Again Rodger
08-30-2014 06:01:37
Beyond what Lonnie said, the sn is on the upper rear-facing portion of the differential, vertical flat portion under half inch wide, and will start with an "S", for steel....often misread as a 5, which gives one too many numbers in the serial number.
Lonnie Smith
08-30-2014 05:25:32
They were used toward the end of WWII, probably made about 15,000 of them. The serial # will be on the outer edge of the round area in the center of the rearend, hand stamped, a little harder to see on these, a steel brush works good.
