WC starter tank valve
mikeintn
Would anyone know where or if its possible to find a fuel shut-off valve for the starter tank on 1936 WC? I don't know what they looked like or where they was placed in the line when new, if anyone knows or have a picture that would be good also. Thanks
I don"t know how to scan and post, but I"ll describe as best I can. The valve is mounted on the bottom side of the tank and appears to have a filter assembly that goes into the tank. Has a simple T handle on it. The valve is not straight- it has a slight offset to it. The tube assembly going to the valve has a complete circular bend in it, going from vertical into the valve, to horizontal going into the carb. The circle is 3-4 inches in diameter.
The tube diameter is not given, but on the power unit both quarter inch and 5/16 inch are used, depending on serial number. The aux tank is mounted so that the valve is near the radiator. There is a fuel line support clamp at the bottom of the circle, and it appears to be bolted to the water pump. There are tractor serial number breakdowns for both the tube and the valve.
