have had starter repaired. have problem no one seems to figure out. tractor runs good..when it runs.... trouble stater will not turn it over...right behind starter it gets very hot and I get blue smoke. figure some kind of wiring gone wrong but no one seems to know what's happening here....I'm desperate. appreciate help. Ed in Okla
Can you post a photo of the starter area indicating what is getting hot?
I'm gonna GUESS there is a grounding issue between the starter and the chassis and battery.
Is the "ground" cable connected as close to the starter as possible (even using a starter mounting bolt), or is is connected to some steel superstructure (dash support, for example) that may not be making good electrical contact with the cast iron chassis/engine/starter?
You could try running a separate ground (even one lead of a set of jumper cables) from the grounded battery post to the metal case of the starter and see if that stops the heating/makes it crank.
(quoted from post at 03:51:49 08/18/14) have had starter repaired. have problem no one seems to figure out. tractor runs good..when it runs.... trouble stater will not turn it over...right behind starter it gets very hot and I get blue smoke. figure some kind of wiring gone wrong but no one seems to know what's happening here....I'm desperate. appreciate help. Ed in Okla
Ed,
Did they replace the bushings?
Mr. T. Minnesota
If it"s like the D17, the battery is just above the starter, and the ground cable attaches to the superstructure/hood support. I like the idea of a separate ground cable between starter and battery- very easy to do, although mine have never had that issue.
