B vs C steering box
No... say if you try to put the wide front of B on a C you end up having to turn left to go right
B box arm points down toward the ground. C box arm points up toward the gas tank. As the arm goes forward the tractors both turn the same direction. Since the C arm is 180 degrees opposite of the B, they have to operate backward inside the gear box.
