CA Govrnor change
You should be able to by removing the distributor housing. What all are you changing and why?
Probly not a governor problem. If you reach behind the carburetor and rev it up and the governor trys to hold it from reving up it will not be a governor problem. It is the governors job to limit and hold rpm's steady to the point the engine has the horse power to do so.
