Just picked up what a believe to be a ’67 D grader. Serial # is 6676. This is a retired utilities grader that was put out to pasture. The motor is tired but was parked running with carburetor problems so the city mechanic took off the carb about two years ago and is now missing. Hopefully he can come up with it in a couple of day???? Anyway, I would like to know if someone can tell me for sure if it’s a ’67 and some engine info such as is it a 226 engine. Can someone tell me if there a tractor I can I can look for that I could get a carb from, if so, what model and year tractor do I need to look for. Any and all info would really be appreciated.... I’m also looking for a service manual for this ’67 model.
Can someone tell me what's going on with the blade?? Seem like there is an attachement welded on at the end of the blade and then for some reason, A portion was cut off with a torch..do you think I can just cut these "added" sections off square?
This grader needs a carburetor, tank cleaning, some hydraulic hose replacing, and one tire to try to get it running again. Once I can get it to run, I would like to restore it so I can put it back to work. Thanks for your help....Joe.
