Calling Dick L...
Chris(WA)
Dick, Any sage advice on getting the brake actuator cam off the shaft so I can replace the brake band in a WF?
My service manual shows it the same setup as a WC.
Remove the brake cover, remove the nut from the end of the band, turn the brake lever so the key is in line with the "V" of the loop of the band. Drive lever towards inside. Key must pass through band and will force inside bushing out.
AaronSEIA
Same pictures in the manual as a WC. Just thought I'd ask.Always like to hear anyone else's experience.
