flywheel bushing
does anyone know what size the bronze bushing is in the flywheel? thinking of putting oil lite ( not sure I spelled that right) bushing in. Does that sound right??
thanks
If you stay with the bushing, oil light will work but you need to check the wick in the crankshaft. They tend to harden and plug not letting oil to the bushing or break down and let too much oil past making the clutch slip. If you replace the bushing with a sealed bearing , you cna plug the crankshaft hole off.
