wd spin put wheels
michlad
New User
is there a solid disc alternative to the spin out wheels on the WD. I have heard rumors that case wheels fit but am unable to confirm this. thanks for any help someone might provide. it has the 8 bolt pattern on the stub axel.
Many combine wheels fit the WD- just measure the centers and bolt pattern. But you lower your ground speed by going to 26 inch wheels, and lose the ability to change wheel widths. I don"t see any advantage to that.
agreed it is not the best option. my dad is 86 and still uses this tractor on a couple small fields and has not changed the wheel width in decades. and he is much slower now so don't think the ground speed will be an issue either..thank you so much for the help. I am certain I can find a cheaper wheel then real replacements for the time being.
Maybe then for safety you want to dish the wheels out- more stable. FWIW I just picked up a pair of Power Shift rims with tubes and so-so tires for $150. Granted, that"s pretty reasonable. They need a little work due to rust.
I have a wd with 16.9 26 rears on it. They are taller than the
original rubber by quite a bit......
