Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
wd spin put wheels
michlad
07-30-2014 09:00:49
is there a solid disc alternative to the spin out wheels on the WD. I have heard rumors that case wheels fit but am unable to confirm this. thanks for any help someone might provide. it has the 8 bolt pattern on the stub axel.
jr1983
08-03-2014 10:58:34
 Re: wd spin put wheels in reply to michlad, 07-30-2014 09:00:49
I have a wd with 16.9 26 rears on it. They are taller than the original rubber by quite a bit......
jr1983
08-01-2014 18:37:31
JMS/.MN
07-30-2014 20:49:16
Many combine wheels fit the WD- just measure the centers and bolt pattern. But you lower your ground speed by going to 26 inch wheels, and lose the ability to change wheel widths. I don"t see any advantage to that.
michlad
07-30-2014 21:34:18
 Re: wd spin put wheels in reply to JMS/.MN, 07-30-2014 20:49:16
agreed it is not the best option. my dad is 86 and still uses this tractor on a couple small fields and has not changed the wheel width in decades. and he is much slower now so don't think the ground speed will be an issue either..thank you so much for the help. I am certain I can find a cheaper wheel then real replacements for the time being.
JMS/.MN
07-31-2014 17:17:16
 Re: wd spin put wheels in reply to michlad, 07-30-2014 21:34:18
Maybe then for safety you want to dish the wheels out- more stable. FWIW I just picked up a pair of Power Shift rims with tubes and so-so tires for $150. Granted, that"s pretty reasonable. They need a little work due to rust.
thebigyellowtruck
07-30-2014 16:42:20
I put 26" case combine wheels on my wd. Fit great!
thebigyellowtruck
07-30-2014 17:18:40
 Re: wd spin put wheels in reply to thebigyellowtruck, 07-30-2014 16:42:20
I guess Stu is way ahead of me about my wheels.
here is my WD with spin out wheels compared to the combine wheels.
Spin-Out Wheels
https://www.facebook.com/photo.php?fbid=1641883719434&set=a.1637243203424.2084189.1007057190&type=3&theater
michlad
07-30-2014 21:36:37
 Re: wd spin put wheels in reply to thebigyellowtruck, 07-30-2014 17:18:40
looks good with the combine tires
stu (ON)
07-30-2014 09:29:35
http://forums.yesterdaystractors.com/viewtopic.php?t=723257&postdays=0&postorder=asc&start=0
