allen niederquell
New User
The reason I got the tractor was the seller said it had a small leak. Yeah, I filled the hydraulic tank up with fluid and when I try to use the rear arms or the loader, the fluid sprays out the bottom by the foot clutch. I thought it was the seal leaking but was told it is probably coming out of the over-flow vent tube just above it (under a plate under the starter). It will drain every bit of fluid if I keep using it. Is the pump maybe not adjusted or could the pump be bad? The vent is not working as an over-flow. It is drain the reservoir tank at high pressure. Anybody with ideas? Thanks
