B clutch - sorry for all the questions
with the help here i have determined I need a 8 1/2" clutch. Don't see a pilot bearing only a bushing in the flywheel . Is that correct or is there a pilot bushing upgrade? I see into the end of the crank and I think that is is oil wick thing - what should it look like? this one does not protrude thru the end of the crank but is wet with oil - is that good?
For a clutch disk is the one with 4 pads the best ?
thanks
yes, the end of the crank is drilled and has a cloth wick stuck in the hole. oil from #4 bearing wets the wick and it drips a controlled (?) amount into the bushing area. The brass bushing is standard. There is no bearing.
