rosedale123
in the process of converting my b to electric - my dad will like it. I have removed the existing clutch and purchase a used clutch with the ring gear. The number stamped in the flywheel is AM 22921 5. I compared the diameters and the ring gear flywheel looks like ( from the mark on the flywheel) it is 8.5 " diameter.... the exising one is 9". does that wound right? I assume ( bad word) I need a new pressure plate and clutch disk ? The bronze bushing in the middle is the same - I that something I should replace? do you guys get the flywheel refaced while it is off?
thanks a ton for your help!
