Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: no spark on WD
07-25-2014 05:28:05
Billy , new cap doesn't rule out bad cap
07-25-2014 05:54:28
 Re: no spark on WD in reply to Billpa, 07-25-2014 05:28:05
Roger that. I will run a continuity test on the cap tonight after work.
07-26-2014 08:03:55
 Re: no spark on WD in reply to Billy_The_Kid, 07-25-2014 05:54:28
Continuity and ohm test indicate no problem with cap.
In searching old threads the mag only shuts spark to one cyl under rare circumstances. I am now leaning toward a points alignment issue. Any other thoughts welcome.
07-28-2014 05:49:21
 Re: no spark on WD in reply to Billy_The_Kid, 07-26-2014 08:03:55
Getting back to everyone who helped me out. The problem turned out to be points that were not adjusted EXACTLY. They were approximately .28 instead of .20. Once I got the points gapped properly, it started running just fine.
The mag is producing lots of spark. After I got the points adjusted right, I held the #1 wire in my hand with spark plug grounded to the frame. WOOOOOOWWWW!!!!! My entire arm will attest to excellent spark! lol
07-25-2014 06:00:42
Billy , let me know how you make out !!!
07-25-2014 06:23:01
 Re: no spark on WD in reply to Billpa, 07-25-2014 06:00:42
Billpa, I will post the results of my test tonight. But two different caps have the same problem with #1, so I'm thinking it's not really a cap issue.
A possible easy fix for this problem is switch out the magneto for a coil/distributor ignition I have. (See new thread I just started.)
