combine engine in CA
lazy A
I recently got a CA and the previous owner said it had a combine or power unit engine in it. What is the difference from a stock engine to one of these and what am i looking for to prove it is a combine engine?
Same block inside, Same crankshaft, Same camshaft. Different pistons. Upgraded pistons and you have the same engine.
I also have a combine power unit in a CA.
The power unit has a shorter govenor spring and runs at a higher RPM. Mine does almost 14 mph on the road. Bob
