Anonymous-0
Hello folks. Was looking for input on a for sale 7040 power shift . All forward gears work but reverse only after revving up and down. The rest of the machine is fair from pics . Asking prices is $4500 and negotiable . My biggest concern is the transmission. Any thoughts , thanks.
$4500 doesn't buy much in 100 plus HP tractors. The early 7000 series powershifts were notorious for shift valve problems. Many changes were made to the racks and links over the course of production. If the tractor operates in all forward gears, my guess is the clutch packs are functioning. Not sure any more which of those clutches are applied in reverse, but my bet is that the valve is having a problem getting one or the other fully engaged when shifted into reverse. If so, you can probably shift the valve back and forth through all the gears and feel something different in one or more positions. Could be an easy fix. easy fix. Maybe even a cable adjustment.
