Engine swap
Direct swap. The only issue might be the carb to air cleaner connection. WD had a smaller carb and smaller air intake hose to match. The air cleaner is a direct swap as well. Pull the fuel tank and take out the 4 bolts. I have seen the WD air cleaner hose cut down and put inside the WD45 line to make a bushing of sorts. Not sure about going the other way. You could run the 45 engine on the WD carb, but might have some issues trying to feed the extra cubes.
AaronSEIA
