7020 starting issues
deerman
Preparing a 7020 for sale. New batteries installed, grounds cleaned up. I have lights, power to the starter solenoid but I get no action when I try to start it. Admittedly I know little about AC but figure I must be missing something. What should I look at next? Should I take starter out and have it checked or is there a switch that I am overlooking? I have in Park, clutch depressed, pump shutoff pulled back, switch on and push button??
Thank you. I assume it must be under the dash near the clutch pedal. Is it a simple 2 wire type pressure switch. Would you happen to have a wiring diagram?
make sure it's in neutral and cross the solenoid first to see if it will run. if it does, run 2 wires to starter and install an aux starter button. easiest way I know of to fix it. AC mechanic's have knowledge of where the safety switches are located and will fix it, the first time the tractor goes in for service!
