Billy_The_Kid
This AC WD (1950) is new to me and has not run in six years. I am getting ready to try to start it, but believe the wiring as I found it was incorrect. The wiring photo shows that a black wire with a red lead coming from the coil is incorrectly attached behind the condenser. I believe it should go to bottom of the points (RED XXX). Condenser should also go to RED XXX, as should the black wire coming from BEHIND the coil (I'm not sure where it is coming from, but I suspect it's a cut-off switch, as the tractor does have an "On/Off" switch.
Can anybody tell me what the correct way to wire the ignition is????
It is a fairbanks morse mag.
I should add that this is a 12 volt system and it is a positive ground system. At least that's the way I found the tractor....
Thank you,
Billy
Thank you,
Billy
