AC B bolt that holds valve cover
I removed the long bolts that are in the head that secure the valve
cover. Noticed the back bolt has a groove ( I assume for oil) - I did
not pay attention what way the groove faced. Is the bolt registered
a certain way??
thanks
It doesn't matter. The hole it screws into has the oil directly under the stud and gets into the grove in any direction. Same deal in the rocker arm stand and rocker arm tube shaft.
