WD 45 transmission shifter
Anonymous-0
WD 45 stuck in first gear, but the shifter wobbles arounds. Took the shifter out and it is not broke. Tried to take the cover off, but it only raised about two inches and will not come off, seems to be hung up on something. Thanks for any ideas on what is wrong and how to fix it.
Since you have the shifter out, with the cover lowered, reach in with a large screwdriver and set the shifting forks so the 3 slots line up with each other. Cover should lift up and out. WD45 should have two line up pins to guide ball of the shifter. If missing or worn, renew them. Check slots in shifter ball for excessive wear...might be able to build them up and recut them.
I have better luck on reassembly if I set the transmission and the shift tower in reverse, then drop it in.
