Jim in NC
I mowed with my C for about an hour and everything worked as it should. Oil and coolant were plentiful and oil pressure was good. Later in the day I went to put it in the shed and it would not turn over. Thinking the battery needed charging, I tried it the next morning and realized that the engine is seized.
Everything under the valve cover looks normal. A neighbor said to check the governor weights. He has seen one break and stop an engine. All is well there.
Yall got any ideas about this. Thanks in advance.
