rosedale123
My new to me '40 B had quite a bit of play in the steering ( probably could move the wheel 30 degrees before front tire movment). Tood the tool box off and removed he steering box and shaft. took it apart and it does not have the "peg" I have seen picture of that wears out. It has a sector gear ( 3 teeth) . It meshes with a worm gear. several gaskets - I assume for adjustment to take out end play the adjustment screw "presses" on the end of the sector gear- to take out endplay ?. The bearngs are good. How do I take out the play or is it just the way it is??
the head has been brazed toward the front where the upper radiator hose is - not too good looking of a braze. previous owner said it needed a valve job. Saw a head that has been manifluxed and valve job - $275 . Am I better getting that or another good head ( musch cheaper) and have it inspected and a valve job - How much is a typical valve job??
Sorry for the lengh- thanks for the help
