rosedale123
Got the " new " b home - never worked on one. couple of questions
when letting the clutch out and the rear wheels just start rolling both wheels " shutter". as soon as they gain a little motion it goes way. Is this normal or is there an adjustment??
Is the change to foot brakes hard..the hand brake thing I have a hard time with - just a little unusual.
read in the manual the clutch should have 1 1/4 inch of free travel. If i measure the movement of the pedal befor it engages the clutch it is 3-4 inches. Is that where you are suppose to measure ? the movement of the clutch rod itself is much less due to the linear travel - is this what I should be measuring?
Is there a adjustment to remove free play from steering?
thanks for all your help
