TractorLinks.com
Show Parts for Model:
Re: WD 45 drawbar pull
big jt
06-14-2014 08:47:06
Some of this depends on where you are. Different soils in different areas pull easier or harder depending.
Around here most 45's were used with a mounted snap coupler 3 bottom plow. My guess if you are using a pull type you should probably use a 2 bottom unless you are going to ballast the bejeberz out of the tractor.
All this is assuming the engine, etc are in decent condition.
jt
BushogPapa
06-15-2014 17:53:18
 Re: WD 45 drawbar pull in reply to big jt, 06-14-2014 08:47:06
In some areas, the WD-45 would pull the AC Semi-Mounted 4x14 plow and never drop below 2nd gear, but it does require all 4 tires be Loaded..
I got so I liked to plow with one Dual on the left and kept that rear wheel slid "in"..
2 of these setups would turn 50 ac/day..(4-Bottom).
With Duals, same size as the inside tires, you should pull a 10' #37 IH disc with 12' Harrow in 3rd gear all day..
Ron.
