D-14 clutch
Anonymous-0
Hi, is there any adjustment to a D-14 foot clutch? I was bushhogging with a 4ft bushhog and a couple times at a woodchuck hole it would stop the tractor cold and slip the clutch, I wonder if there's any adjustment or if the clutch is about to go. Thank you
Eric
Pull the cotter pin out of the rod, at the bottom of the clutch pedal, and disconnect the rod from the pedal. Then loosen or tighten, by threading or unthreading the rod from the TO bearing yoke.
