I am thinking i have a hyro issue, As the tractor started to slip in high range, now high range does not work at all. Low range however works fine, Now I have noticed that the tractor will slip in low range if your have the wheel turned sharp. Does anyone have any ideals.
Check hyd fluid levels and filter. Hook an implement to the pto and try, if the clutches slip and the pto slows down or stops it's the main clutch , if the pto keeps going strong it's the high-low range clutches and probably needs replacing. Gene
Check the linkage to the power director valve. Look for worn bshings on the bellcrank. It also could be a linkage adjustment problem.
